[postgis-users] match line with road segment
searchelite searchelite at gmail.com
Thu Jul 17 07:23:32 PDT 2008
Paragon Corporation-2 wrote:
> You may be better off snapping the points to the line first before you do
> a
> make line.  Take a look at Paul's blog entry.
> http://blog.cleverelephant.ca/2008/04/snapping-points-in-postgis.html
> Sounds similar to what you are trying to do.
> Hope that helps,
> Regina
Thanks for the reply...Yes, I already did that (snapping the point to the
line)..so, is there any idea what should i do next?
thanks
View this message in context: http://www.nabble.com/match-line-with-road-segment-tp18479996p18509643.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
