[postgis-users] R: match line with road segment
searchelite searchelite at gmail.com
Thu Jul 17 09:09:59 PDT 2008
P.Rizzi Ag.Mobilità Ambiente wrote:
> If I undestood it well enough and you are trying to match
> GPS tracked points upon a road system, you should be careful
> about crossings.
> Where two roads cross, a GPS point may be nearer to the crossing road
> instead of the one the vehicle actually was.
> So you should ensure to somehow "stick" to the "correct" road.
> Maybe by calculating the azimuth of each individual two-consecutive-points
> segment and searching for the road nearest to the ending point
> of the segment _and_ with the azimuth most similar to the segment itself.
> Obviuosly sometimes a vehicle actually turns into a crossing road,
> so you should also recognize that somehow and _don't_ "stick" in that
> case...
> Bye
> Paolo Rizzi
Thanks for the idea paolo..yes i've been considered that case..thank you
again
View this message in context: http://www.nabble.com/match-line-with-road-segment-tp18479996p18512150.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
