[postgis-users] Postgis to ESRI shape file encoding problem
Ervin Ramonllari
ervin.ramonllari at hotmail.com
Mon Jul 21 06:34:31 PDT 2008
Ok, thnx
but i have tried this solution before.
It looks like a problem with the shape or most probably with the dbf file encoding. the dbf encoding should be SQL_ASCII.
Actually, if you try to save an Excel spreadsheet( which contains special character - Ë, Ç ) as a dbf file, the result is the same as in my exercise. The special characters can later be replace by using ArcView or ArcMap.
I just decided to remove my special characters from my database, so it's not a concern anymore (for this time, a solution has to be found anyway).
Just, for curiosity, has somebody had the same problem as mine?
Thanks to all you guys,
regards
Ervin
To: postgis-users at postgis.refractions.net
CC: postgis-users at postgis.refractions.net; postgis-users-bounces at postgis.refractions.net
Subject: RE: [postgis-users] Postgis to ESRI shape file encoding problem
Date: Mon, 21 Jul 2008 14:48:20 +0300
Hello,
You have an error in this sentence,
you should use it like this
ALTER DATABASE DBIPRS
SET client_encoding=latin2;
Regards
Maher
Ervin Ramonllari <ervin.ramonllari at hotmail.com>
Sent by: postgis-users-bounces at postgis.refractions.net
07/21/2008 01:33 PM
Please respond to PostGIS Users Discussion
To:
PostGIS Users Discussion <postgis-users at postgis.refractions.net>
cc:
Subject:
I tried this way :
ALTER DATABASE DBIPRS SET PGCLIENTENCODING to 'Latin2'
but i got the error:
ERROR: unrecognized configuration parameter
"pgclientencoding"
SQL state: 42704
> Date: Sat, 19 Jul 2008 14:37:37 +0200
> From: sdteffen at gmail.com
> Subject: Re: [postgis-users] Postgis to ESRI shape file encoding problem
> You can also try to set the environment variable PGCLIENTENCODING
to the
> encoding value you need (e.g. LATIN2).
> Steffen
> >> I'm trying to export some data from a Postgresql database
encoded in UTF-8
> >> into some ESRI shape files.
> >> I'm using PostGIS Dumper (pgsql2shp).
> postgis-users mailing list
Discover the new Windows Vista Learn
more!_______________________________________________
_________________________________________________________________
http://search.msn.com/results.aspx?q=windows+vista&mkt=en-US&form=QBRE
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080721/8ca41b3c/attachment.html>
