[postgis-users] performence of function "GOES.WKBreader.readerHex() "
anigold
anigold at 163.com
Sun Jul 27 18:20:51 PDT 2008
hi.all
i'm new to postgis and GEOS.In recent days i wrote a application based on 'postgis' and 'GEOS'. and everything is OK. but it is REALLY long time to finish the function:
geos::geom::Geomtry* pgeom = GOES.WKBreader.readerHex(...);
i import a shp file ( polygon type,1.4M exclude dbf file size ) to db,the function above need 3500ms to finish.
i try the QGIS application and found it works good in speed.
can anyone give some ideas to improve it?
i use libpq to access the postgresql.
much thanks.
anakin.jin
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080728/0d651aa0/attachment.html>
