[postgis-users] encoding and german umlaute
Paul Ramsey pramsey at cleverelephant.ca
Mon Jul 28 11:53:23 PDT 2008
Great point, Regina. Note that this won't work if your database is
SQL-ASCII. If it's UTF8 it should work like a hot damn though.
P.
On Mon, Jul 28, 2008 at 11:31 AM, Paragon Corporation <lr at pcorp.us> wrote:
> You could also set the client encoding at the database level if setting it
> in Manifold is not an option and all you clients expect latin1.  Although
> that is slightly more invasive.
> To set at the database level - do one of the following
> 1) In PgAdmin right click the database - go to variables tab
> 2) pick client_encoding and set value to latin1
> Or the SQL way
> ALTER DATABASE somedatabase SET client_encoding=latin1;
> Hope that helps,
> Regina
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Paul
> Ramsey
> Sent: Monday, July 28, 2008 1:08 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] encoding and german umlaute
> Judging from the gook you're getting in your second example (two characters
> for every hibit character) the database probably has the data encoded as
> UTF-8.
> - If your database encoding is UTF8 (use psql -l for a listing of
> databases) then the problem is Manifolds fault... for some reason it's
> receiving UTF8 but interpreting it as LATIN1.  If you can tell it to "set
> client_encoding = latin1" somehow, that might help. Otherwise, complain to
> them, they should set their client encoding correctly as part of their
> interaction with the database.
> - If your database encoding is SQL-ASCII then the problem is your fault...
> you've loaded encoded data but not specified the encoding, so the software,
> both PgSQL and Manifold, can't create a nice processing chain to ensure it
> is rendered correctly. Correct renderings of your data can sometimes happen,
> but only by chance. In this case, dump your data and restore it into a UTF8
> database.
> P.
> On Mon, Jul 28, 2008 at 9:58 AM, gisworks <stefan.overkamp at gisworks.de>
> wrote:
>> Hi,
>> I'm using postgresql and manifold GIS. With manifold 8.0.8 connecting
>> to my postgres-Database shows scrambled german Umlaute (ä, ö, ü, ß,
>> and so on) in text fields.
>> Connecting with manifold 8.0.7 the text is shown correct like in pgadmin:
>> "Fläche für die Landwirtschaft"
>> Connecting with manifold 8.0.8 the text is shown as: "Fläche für die
>> Landwirtschaft"
>> Maybe there is a solution on the postgres side. Are there any
>> tutorials on the setup of encoding to allow german umlaute?
>> What configuration would german users use when installing postgresql
> 8.3.3:
>> initdb locale, encoding ... ?
>> Which encoding I have to use on database creation?
>> What is setting client_encoding about?
>> Thanks
>> View this message in context:
>> http://www.nabble.com/encoding-and-german-umlaute-tp18694836p18694836.
>> html Sent from the PostGIS - User mailing list archive at Nabble.com.
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
