[postgis-users] problem to transform coordinates
Felipe Fedel Pinto fedelfelipe at gmail.com
Wed Jul 30 16:25:50 PDT 2008
To transform coordinates in PostGis I use the followed function:
UPDATE <table> SET <new_geometry_column> =
transform(<original_geometry_column>,<new_SRID>);
I have been having a weird problem when I try to transform coordinates that
are in a SRID=22523.
Ex: I have to transform them to a SRID=4326
UPDATE coordsformiga SET coord_4326 = transform(coord_22523,4326);
where coordsformiga is the table,
          coord_22523 is the original geometry column with the coordinates
in a SRID=22523
          coord_4326 I'd be the geometry column with the coordinates
transformed in a SRID=4326
the problem is:
After the function, in the geometry column (coord_4326), all of the 97
coordinates have the same values.
But it's happening only with a SRID=22523.
Anybody knows what is happening??
thanks
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080730/d4306c94/attachment.html>
