[postgis-users] Re: Can't Call shp2pgsql.exe From "Run" or VB Program, only works with DOS prompt opened first
Dan Blomberg
services at gpsfiledepot.com
Sun Jun 1 14:50:26 PDT 2008
Everyone,
I actually figured out how to make this work by viewing the php code for
the DCMMS application. I needed to add the database after the table
name and now it works.
In case anyone else runs into this the command I now use is:
"C:\gps_maps\postgis_sql\shp2pgsql.exe" -d
"C:\gps_maps\mississippi_topo\transportation\all_lines.shp" all_lines
postgis > "C:\gps_maps\mississippi_topo\transportation\all_lines.sql"
Dan
Daniel Blomberg wrote:
> Paul & Regina,
> Paul: I noticed there is no -f option. Would I be able to run a command direct to psql (with the | ) without having to open the command prompt first?
> Regina: I tried that, good idea though.
> More diagnosing: I am able to run pgsql from my program without an issue. I tried to run shp2pgsql.exe from a .bat file I wrote and it also has the same error. Anyone else have any ideas?
> Thanks
> Dan
> QUOTED:
> Message: 4
> Date: Sun, 1 Jun 2008 06:39:09 -0400
> From: "Paragon Corporation" <lr at pcorp.us <mailto:lr at pcorp.us>>
> Subject: RE: [postgis-users] Can't Call shp2pgsql.exe From "Run" or VB
> To: "'PostGIS Users Discussion'"
> <postgis-users at postgis.refractions.net <mailto:postgis-users at postgis.refractions.net>>
> Message-ID: <000501c8c3d3$b936ef00$4d812e40 at l>
> Content-Type: text/plain; charset="us-ascii"
> Dan,
> Could also be the VB code or run statement is being truncated. How are you
> escaping out your double quotes in VB.
> E.g. if you copy the files to root of C and then try it does it work?
> Hope that helps,
> Regina
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net <mailto:postgis-users-bounces at postgis.refractions.net>
> [mailto:postgis-users-bounces at postgis.refractions.net <mailto:postgis-users-bounces at postgis.refractions.net>] On Behalf Of Paul
> Ramsey
> Sent: Saturday, May 31, 2008 6:05 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] Can't Call shp2pgsql.exe From "Run" or VB
> Program,only works with DOS prompt opened first
> The redirect may not work when running it from Run... or exec inside a
> program. This sort of argues for a -f option to write out to file without
> needing a stdout redirect.
> P
> On Sat, May 31, 2008 at 2:49 PM, Daniel Blomberg <services at gpsfiledepot.com <mailto:services at gpsfiledepot.com>>
> wrote:
>> Hi,
>> I am trying to run shp2pgsql.exe from inside a visual basic program I
>> am writing. Its not working so i tested the command I am sending from
>> the "Run" dialog box in windows and it doesn't work. The dos box pops
>> up and goes away too fast but here is what I caught:
>> http://www.gpsfiledepot.com/shp2pgsql.jpg
>> The command I am trying to run is:
>> If I run the command when the dos prompt is open it works. Ideas/help
>> would be much appreciated.
>> Thanks in advance
>> Dan
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080601/2965b0d8/attachment.html>
