[postgis-users] pgsql2shp syntax - sentence construction
SenTnel elvin.pimentel at gmail.com
Mon Jun 2 20:49:20 PDT 2008
Thanks again Kishor!
The situation is that I work at a Truck Company and we keep a gps vehicle
location service using geoserver and openlayers, our shapefiles were
converted to postgis to be able to display the maps with the vehicle's
positions.
P Kishor-3 wrote:
> On 6/2/08, SenTnel <elvin.pimentel at gmail.com> wrote:
>>  Thanks Kishor!
>>  >If you are not changing the geometry, you can do all your attribute
>>  >updates as simple SQL updates
>> Some changes are just name corrections, but I need also update the maps
>> with
>>  new streets and roads, and that is the most important updates that needs
>> to
>>  be done, since our maps are couple of years old and there are many new
>>  streets to add and that's why Im asking if the best way is to dump
>> postgres
>>  to shape, update and then convert it again. What do you think is the
>> best
>>  way to achive this updating process?
> If you have update a lot of geometry manually, and if you have ArcMap,
> then yes, this is probably the easiest route. That is what I would do.
> Why do you even have your 2 years old data in PostGIS? Mind you, I am
> *for* PostGIS. But, I am wondering -- unless there is a good reason to
> take on the complexity of Postgres/PostGIS, why not just keep your
> data in Shapefile format?
>>  Thanks again!
>>  >>  Thanks Stephen!
>>  >>  I must admit that Im not good at this, but Im determined to mantain
>> my
>>  >>  city's database correcting names and roads classifications, etc.,
>> that's
>>  >> why
>>  >>  I need to take the postgres data and convert it to shapefile, then
>>  >> correct
>>  >>  things with arcmap, then drop the old postgres data and then
>> re-convert
>>  >> the
>>  >>  updated shapefile to postgres, is this the way you would do it?
>>  > updates as simple SQL updates (see below).
>>  >>  I have one more question about this updating, and this is a "select"
>>  >>  question, (I'll remind you that Im an ignorant in this matters)
>> would
>>  >> you
>>  >>  please construct an sql sentence to achive this:
>>  >>  In mydatabase, myschema, mytable there's a "street" column, where
>> the
>>  >> street
>>  >>  names are, let's say I want to correct a misspeled name, for
>> example,
>>  >> "Geoge
>>  >>  Washington", and want to correct it to "George Washington", how do
>> you
>>  >> write
>>  >>  the select?
>>  > UPDATE mytable
>>  > SET street = 'George Washington'
>>  > WHERE street = 'Geoge Washington'
>>  > Note the single quotes to delimit the text strings.
>>  > You might do well do spend some time looking a few basic SQL tutorials
>>  > before launching ahead. You will get more mileage from the tutorials
>>  > than from asking these simple questions on list.
>>  > http://www.google.com/search?q=sql+tutorial
>>  >>  Thanks again!
>>  >>  Stephen Woodbridge wrote:
>>  >>  > SenTnel wrote:
>>  >>  >> Hi! Im working with postgres and geoserver but im just not good
>> at
>>  >> sql
>>  >>  >> statements, none the less in construction sentences in postgres,
>> and
>>  >> I
>>  >>  >> would
>>  >>  >> like to create a shapefile from a table in postgres and don't
>> want to
>>  >>  >> make a
>>  >>  >> costly mistake, so if you help me achieve this using pgsql2shp:
>>  >>  >> database name: mydatabase
>>  >>  >> schema: myschema
>>  >>  >> table: mytable
>>  >>  >> shapefile to be created: updatedshp
>>  >>  >> database user: postgres
>>  >>  >> password: any
>>  >>  >> can you help me with the syntax to achieve the shapefile
>> containing
>>  >> all
>>  >>  >> of
>>  >>  >> the data (and geom) in such table?
>>  >>  >> Thanks !
>>  >>  > SenTel,
>>  >>  > pgsql2shp is not a SQL statement it is a command line tool:
>>  >>  > woodbri at carto:~$ pgsql2shp
>>  >>  > RCSID: $Id: pgsql2shp.c,v 1.82 2006/01/16 10:42:57 strk Exp $
>>  >>  > USAGE: pgsql2shp [<options>] <database> [<schema>.]<table>
>>  >>  >         pgsql2shp [<options>] <database> <query>
>>  >>  > OPTIONS:
>>  >>  >    -f <filename>  Use this option to specify the name of the file
>>  >>  >       to create.
>>  >>  >    -h <host>  Allows you to specify connection to a database on a
>>  >>  >       machine other than the default.
>>  >>  >    -p <port>  Allows you to specify a database port other than the
>>  >>  > default.
>>  >>  >    -P <password>  Connect to the database with the specified
>> password.
>>  >>  >    -u <user>  Connect to the database as the specified user.
>>  >>  >    -g <geometry_column> Specify the geometry column to be
>> exported.
>>  >>  >    -b Use a binary cursor.
>>  >>  >    -r Raw mode. Do not assume table has been created by
>>  >>  >       the loader. This would not unescape attribute names
>>  >>  >       and will not skip the 'gid' attribute.
>>  >>  >    -k Keep postgresql identifiers case.
>>  >>  > So you might use it like:
>>  >>  >> pgsql2shp -f updatedshp.shp -h localhost -u postgres mydatabase
>>  >>  >> myschema.mytable
>>  >>  > Have fun,
>>  >>  >    -Steve W
>>  >>  > _______________________________________________
>>  >>  > postgis-users mailing list
>>  >>  > postgis-users at postgis.refractions.net
>>  >>  > http://postgis.refractions.net/mailman/listinfo/postgis-users
>>  >>  View this message in context:
>> http://www.nabble.com/pgsql2shp-syntax---sentence-construction-tp17613265p17613906.html
>>  >>  Sent from the PostGIS - User mailing list archive at Nabble.com.
>> http://www.nabble.com/pgsql2shp-syntax---sentence-construction-tp17613265p17614606.html
> Puneet Kishor http://punkish.eidesis.org/
> Nelson Institute for Environmental Studies http://www.nelson.wisc.edu/
> Open Source Geospatial Foundation (OSGeo) http://www.osgeo.org/
View this message in context: http://www.nabble.com/pgsql2shp-syntax---sentence-construction-tp17613265p17615545.html
