[postgis-users] How to tell if 2 geometries are spatially equal
Martin Davis
mbdavis at refractions.net
Tue Jun 3 13:37:43 PDT 2008
As someone who spent way too much time implementing topological
processing in the SFS model, I can comment on this. The "finite
point-set of intersection" rule for Polygonal geometry actually make a
lot of sense, since it makes algorithm design easier and execution more
efficient. With this rule in place algorithms can assume that an edge
of a polygonal geometry has interior on one side and exterior on the
other. This makes topological labelling easier. Also, in certain
computations you can determine an answer without having to compute the
entire topology of a geometry. (The optimized PreparedGeometry
predicates in JTS and GEOS depend on this, for instance).
Andy Anderson wrote:
> Ah. Not a big deal in 2 dimensions, but I have a real problem with
> this in 3D! :-) But I see in OGC 99-049 where they say:
> "A Polyhedral Surface is not a MultiPolygon because it violates the
> rule for MultiPolygons that the boundaries of the element Polygons
> intersect only at a finite number of points."
> Seems like an unnecessary restriction, but I'm sure they have their
> reasons for excluding this "degenerate" case.
> -- Andy
>>> I'll also note that, to be consistent, this must also mean that
>>> MULTIPOLYGON((0 0, 5 5, 5 0, 0 0), (0 0, 0 5, 5 5, 0 0)) doesn't
>>> have a boundary line at LINESTRING(0 0, 5 5).
>> Well, that Multipolygon is actually invalid - since MPs can't have
>> coincident line segments. So the definition *is* consistent!
>>> I'm not sure which one that is.
>> It's the OGC document 99-049 (the first one you sent)
>> Martin Davis
>> Senior Technical Architect
>> Refractions Research, Inc.
>> (250) 383-3022
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
Martin Davis
(250) 383-3022
