[postgis-users] Intersection - No GID
SenTnel
elvin.pimentel at gmail.com
Tue Jun 3 15:12:20 PDT 2008
Hi... again! =^D
While Im learning about this exciting new area to me Im going thru some SQL
tutorials, but so far can't find an answer to this dilema I have:
My database has a lot of empty "street" fields, meaning that a lot of
streets has no name registered, they're just plain blank, so I can't enter
the proper "road clasification", so they don't show up in the maps because
the SLD has clasifications for "street", "avenue" and "highway".
What I would like to do is to INSERT something like "N/A" (Not Available) in
every field that is empty in the "street" column, but don't know exactly the
SQL statemet to tell:
"In mytable, street column, insert 'N/A' in every empty space"
I owe you one more!
Thanks!!
marcuscengland wrote:
> Thank you... this did the trick.
> Obe, Regina wrote:
>> Marcus,
>> Just to add to some things that Robert said.
>> 1) You can also add the serial after the fact with a
>> ALTER TABLE new_fields ADD COLUMN gid serial;
>> ALTER TABLE new_fields ADD CONSTRAINT pk_new_fields PRIMARY KEY(gid);
>> 3) ST_Intersects is different from Intersects although ST_Intersection
>> is the same as Intersection. It includes the && operator so you can
>> leave out the && in it
>> CREATE TABLE new_fields AS
>> SELECT
>> ST_Intersection(f.the_geom, c.the_geom) AS the_geom,
>> f.attr1,
>> f.attr2,
>> c.clu_name
>> FROM
>> fields f,
>> clu c
>> WHERE
>> ST_Intersects(f.the_geom, c.the_geom)
>> Hope that hleps,
>> Regina
>> *From:* postgis-users-bounces at postgis.refractions.net
>> [mailto:postgis-users-bounces at postgis.refractions.net] *On Behalf Of
>> *Burgholzer,Robert
>> *Sent:* Tuesday, June 03, 2008 3:07 PM
>> *To:* marcuscengland at gmail.com; PostGIS Users Discussion; PostGIS
>> Users Discussion
>> *Subject:* RE: [postgis-users] Intersection - No GID
>> Marcus,
>> 1) You could create your table prior to populating it, and include a
>> column that is type "SERIAL", this will create an autogenerated
>> integer identifier that you could name "gid" if you so desired.
>> 2) select area2d(Intersection(f.the_geom, c.the_geom)) ...
>> NOTE: You will have to convert this area2d result from the units of
>> your map projection into acres
>> 3) ST_intersection and intersection are the same, the new (ST_*)
>> naming convention was recently added, for reasons that I do not know
>> but assume that they were good ones.
>> HTH,
>> Robert
>> -----Original Message-----
>> From: postgis-users-bounces at postgis.refractions.net on behalf of
>> Marcus C. England
>> Sent: Tue 6/3/2008 2:57 PM
>> To: PostGIS Users Discussion
>> Cc:
>> Subject: [postgis-users] Intersection - No GID
>> Hi all,
>> I figured out how to use Intersection and get a resulting table with
>> apparently correct results using the example from the PostGIS website:
>> SELECT
>> f.attr1,
>> f.attr2,
>> c.clu_name
>> FROM
>> fields f,
>> clu c
>> WHERE
>> f.the_geom && c.the_geom
>> AND
>> However, this example does not create a gid column and I therefore can
>> not view the results in a GIS program. Is there a way to create a gid
>> column after-the-fact?
>> Optional questions for those feeling super-helpful:
>> (1) How should the above SQL be rewritten to include gid in the
>> resulting table?
>> (2) I know that eliminating the first line will simply give me a table
>> spit onto the SQL results in pgAdmin. How do I alter the SQL above to
>> give me the acreages rather then a list of the geometries? I can get the
>> acreages from the table resulting from the above, but I can't figure out
>> how to skip the step of creating a table.
>> (3) What is the syntax using ST_Intersection rather than Intersection?
>> thanks,
>> Marcus
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> *The substance of this message, including any attachments, may be
>> confidential, legally privileged and/or exempt from disclosure
>> pursuant to Massachusetts law. It is intended solely for the
>> addressee. If you received this in error, please contact the sender
>> and delete the material from any computer. *
>> * Help make the earth a greener place. If at all possible resist
>> printing this email and join us in saving paper. *
View this message in context: http://www.nabble.com/pgsql2shp-syntax---sentence-construction-tp17613265p17634973.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
