[postgis-users] Intersection - No GID
P Kishor
punk.kish at gmail.com
Tue Jun 3 17:31:00 PDT 2008
On 6/3/08, SenTnel <elvin.pimentel at gmail.com> wrote:
> Hi... again! =^D
> While Im learning about this exciting new area to me Im going thru some SQL
> tutorials, but so far can't find an answer to this dilema I have:
> My database has a lot of empty "street" fields, meaning that a lot of
> streets has no name registered, they're just plain blank, so I can't enter
> the proper "road clasification", so they don't show up in the maps because
> the SLD has clasifications for "street", "avenue" and "highway".
> What I would like to do is to INSERT something like "N/A" (Not Available) in
> every field that is empty in the "street" column, but don't know exactly the
> SQL statemet to tell:
> "In mytable, street column, insert 'N/A' in every empty space"
Did you really do any of the tutorials? Most of them will cover
something like...
UPDATE mytable
SET street = 'N/A'
WHERE street = '' OR street IS NULL
> I owe you one more!
> Thanks!!
> marcuscengland wrote:
> > Thank you... this did the trick.
> > Obe, Regina wrote:
> >> Marcus,
> >> Just to add to some things that Robert said.
> >> 1) You can also add the serial after the fact with a
> >> ALTER TABLE new_fields ADD COLUMN gid serial;
> >> ALTER TABLE new_fields ADD CONSTRAINT pk_new_fields PRIMARY KEY(gid);
> >> 3) ST_Intersects is different from Intersects although ST_Intersection
> >> is the same as Intersection. It includes the && operator so you can
> >> leave out the && in it
> >> CREATE TABLE new_fields AS
> >> SELECT
> >> ST_Intersection(f.the_geom, c.the_geom) AS the_geom,
> >> f.attr1,
> >> f.attr2,
> >> c.clu_name
> >> FROM
> >> fields f,
> >> clu c
> >> WHERE
> >> ST_Intersects(f.the_geom, c.the_geom)
> >> Hope that hleps,
> >> Regina
> >> *From:* postgis-users-bounces at postgis.refractions.net
> >> [mailto:postgis-users-bounces at postgis.refractions.net] *On Behalf Of
> >> *Burgholzer,Robert
> >> *Sent:* Tuesday, June 03, 2008 3:07 PM
> >> *To:* marcuscengland at gmail.com; PostGIS Users Discussion; PostGIS
> >> Users Discussion
> >> *Subject:* RE: [postgis-users] Intersection - No GID
> >> Marcus,
> >> 1) You could create your table prior to populating it, and include a
> >> column that is type "SERIAL", this will create an autogenerated
> >> integer identifier that you could name "gid" if you so desired.
> >> 2) select area2d(Intersection(f.the_geom, c.the_geom)) ...
> >> NOTE: You will have to convert this area2d result from the units of
> >> your map projection into acres
> >> 3) ST_intersection and intersection are the same, the new (ST_*)
> >> naming convention was recently added, for reasons that I do not know
> >> but assume that they were good ones.
> >> HTH,
> >> Robert
> >> -----Original Message-----
> >> From: postgis-users-bounces at postgis.refractions.net on behalf of
> >> Marcus C. England
> >> Sent: Tue 6/3/2008 2:57 PM
> >> To: PostGIS Users Discussion
> >> Cc:
> >> Subject: [postgis-users] Intersection - No GID
> >> Hi all,
> >> I figured out how to use Intersection and get a resulting table with
> >> apparently correct results using the example from the PostGIS website:
> >> SELECT
> >> f.attr1,
> >> f.attr2,
> >> c.clu_name
> >> FROM
> >> fields f,
> >> clu c
> >> WHERE
> >> f.the_geom && c.the_geom
> >> AND
> >> However, this example does not create a gid column and I therefore can
> >> not view the results in a GIS program. Is there a way to create a gid
> >> column after-the-fact?
> >> Optional questions for those feeling super-helpful:
> >> (1) How should the above SQL be rewritten to include gid in the
> >> resulting table?
> >> (2) I know that eliminating the first line will simply give me a table
> >> spit onto the SQL results in pgAdmin. How do I alter the SQL above to
> >> give me the acreages rather then a list of the geometries? I can get the
> >> acreages from the table resulting from the above, but I can't figure out
> >> how to skip the step of creating a table.
> >> (3) What is the syntax using ST_Intersection rather than Intersection?
> >> thanks,
> >> Marcus
> >> _______________________________________________
> >> postgis-users mailing list
> >> postgis-users at postgis.refractions.net
> >> http://postgis.refractions.net/mailman/listinfo/postgis-users
> >> *The substance of this message, including any attachments, may be
> >> confidential, legally privileged and/or exempt from disclosure
> >> pursuant to Massachusetts law. It is intended solely for the
> >> addressee. If you received this in error, please contact the sender
> >> and delete the material from any computer. *
> >> * Help make the earth a greener place. If at all possible resist
> >> printing this email and join us in saving paper. *
> View this message in context: http://www.nabble.com/pgsql2shp-syntax---sentence-construction-tp17613265p17634973.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
