[postgis-users] create tables smarter
Lee Hachadoorian
lee.hachadoorian at gmail.com
Wed Jun 4 08:10:18 PDT 2008
Andreas,
AddGeometryColumn does two things: it adds a column of type geometry,
and it adds a row to table geometry_columns. If I understand what it
is you want to do, you can do the SELECT and then add the row to
geometry_columns with an INSERT statement:
INSERT INTO public.geometry_columns
VALUES ('',<schema_name>,<table_name>,<column_name>,<dimension>,<srid>,<type>);
where the arguments use the same values you would use for the
AddGeometryColumn function.
Stephen, I don't see anything about a probegeometrycolumns( ) function
in the PostGIS docs. Can you point me in the right direction?
Thanks,
Lee Hachadoorian
PhD Student, Geography
Program in Earth & Environmental Sciences
CUNY Graduate Center
