[postgis-users] GIST index speed
Ries van Twisk postgis at rvt.dds.nl
Wed Jun 4 17:03:24 PDT 2008
> First, basic index concepts: when you are requesting the whole data
> set, the index (any index) does *nothing* for your performance.  To
> use an (obsolete) metaphor, if you are checking out *every* book in
> the library, do you first go to the card catalog?
> So your test case isn't testing anything index related.
> Step one: is something seriously wrong with your database setup? Is
> this query pretty fast: SELECT Count(*) FROM asdfs_track_point
> It should be, counting to 42000 doesn't take long.
> Step two: why *is* your SQL case slow? Doing anything 42000 times
> shouldn't take long, particularly since one of your arguments is
> simple and small.
> Unless... your geometries are extremely big, or your tuples are
> extremely wide.  Do you have a large large number of columns?  How
> many vertices in your geometries?
> P.
I would do a count on the complete set including the WHERE clause,
much like this :
SELECT count(*) FROM asdfs_track_point where
within(the_geom,GeometryFromText('POLYGON((-180.0 -90.0,-180.0
90.0,180.0
90.0,180.0 -90.0,-180.0 -90.0))',4326));
The reason is the eliminate the need for data transfer. I have seen
occassions where
datatransfer (from DB to client) was the issue... I mention this
because you didn't mention
your setup.
Second do an explain analyze..
Ries
> On Wed, Jun 4, 2008 at 4:05 PM, Peck, Brian <brian.peck at lmco.com>
> wrote:
>> Hey all,
>> I currently am working on a PostGIS database (Postgres 8.3) and the
>> requests
>> are going slower than expected.
>> The table I'm querying off of has ~42000 entries in it, and the
>> geometry
>> field I'm using has a gist index on it. The query however is taking
>> ~6
>> seconds to return me the entries.
>> I am making the query
>> SELECT * FROM asdfs_track_point where
>> 90.0,180.0
>> This is a test case and so I am doing the entire world to find out
>> how long
>> things should take, but I'm told that with only 42000 rows in the
>> table it
>> should be faster than 6 seconds.
>> Anyone have any idea why it might be going slow, or a way to speed
>> up the
>> query?
>> Thanks,
>> - Brian Peck
>> - 858-795-1398
>> - Software Engineer
>> - Lockheed Martin
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
