[postgis-users] attempt to deserialize a point which is really aInvalid type
Obe, Regina
robe.dnd at cityofboston.gov
Thu Jun 5 04:55:13 PDT 2008
Adding SRID makes it an invalid geometry so the text will not be
automatically cast to a geometry. Your point doesn't look like 3395
point anyway
SELECT name, distance_spheroid(location, 'POINT(-3.6620213
40.4475235)', 'SPHEROID["WGS 84",6378137,298.257223563]') as distance
FROM ways
Also note if your point was actually in 3395 projection you'll get very
laughable results with distance_spheriod because distance_spheriod/shpe*
always assumes degrees regardless of what the srid of your data says it
is.
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Ricardo Peironcely
Sent: Thursday, June 05, 2008 7:13 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] attempt to deserialize a point which is really
aInvalid type
Hello all!
I've a problem, when I try to calculate a distance:
SELECT name, distance_spheroid(location, 'SRID=3395;POINT(-3.6620213
FROM ways
receive an error :
ERROR: lwpoint_deserialize: attempt to deserialize a point which is
really a Invalid type
Estado SQL:XX000
What is the problem? Google doesn't says anything about this error.
Best regards.
Ricardo Peironcely
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
