[postgis-users] Intersection - three tables
Sufficool, Stanley ssufficool at rov.sbcounty.gov
Thu Jun 5 17:00:40 PDT 2008
The sum of the intersecting area of all 3 polygons.
Sum(area2d(ST_Intersection(ST_Intersection(n.the_geom, f.the_geom),
c.the_geom)))*0.000247105381
> Hello all,
> Well, I'm learning fast but I have come across a problem that
> perplexes
> me. I have three polygon tables. "new_vegetation" represents
> vegetation
> on a site. "grading_phases" represents the grading area for a
> project,
> and this is entirely within the limits of "new_vegetation". The third
> layer is "basin_grading", which represents five proposed
> basins (as well
> as polygons for 100' and 200' buffers around those basins), some of
> which are within "grading_phases" and some of which are outside of
> "grading_phases". Some are even split between being and out of
> grading_phases.
> What I am trying to get is the acreage of vegetation communities
> (new_vegetation) within the each polygon type of
> basin_grading, but only
> those portions that are within grading_phases. The query below is my
> attempt at this, but it returns the acreage of new_vegetation within
> each entire basin, not just the portion that is also within
> grading_phases. I thought the ST_Intersects part would take care of
> that, but apparently not.
> SELECT
>    f.use,
>    n.cat_2008,
>    Sum(area2d(ST_Intersection(n.the_geom, f.the_geom)))*0.000247105381
> AS inside_project
>  FROM
>    basin_grading f,
>    grading_phases c,
>    new_vegetation n
>  WHERE
>    ST_Intersects(c.the_geom, f.the_geom)
>  GROUP BY f.use, n.cat_2008
>  ORDER BY f.use, n.cat_2008
> thanks in advance,
> Marcus
> postgis-users mailing list postgis-users at postgis.refractions.net
