[postgis-users] Intersection - three tables
Marcus C. England marcuscengland at gmail.com
Thu Jun 5 19:14:30 PDT 2008
Hi Stanley,
I tried that several times and it never worked. Nonetheless, I copied
your text and placed it into my query (replacing the original sum
function) and it still did not work. I get this:
NOTICE:  IllegalArgumentException: This method does not support
GeometryCollection arguments
ERROR:  GEOS Intersection() threw an error!
********** Error **********
SQL state: XX000
-Marcus
Sufficool, Stanley wrote:
> The sum of the intersecting area of all 3 polygons.
> Sum(area2d(ST_Intersection(ST_Intersection(n.the_geom, f.the_geom),
> c.the_geom)))*0.000247105381
>> Hello all,
>> Well, I'm learning fast but I have come across a problem that
>> perplexes
>> me. I have three polygon tables. "new_vegetation" represents
>> vegetation
>> on a site. "grading_phases" represents the grading area for a
>> project,
>> and this is entirely within the limits of "new_vegetation". The third
>> layer is "basin_grading", which represents five proposed
>> basins (as well
>> as polygons for 100' and 200' buffers around those basins), some of
>> which are within "grading_phases" and some of which are outside of
>> "grading_phases". Some are even split between being and out of
>> grading_phases.
>> What I am trying to get is the acreage of vegetation communities
>> (new_vegetation) within the each polygon type of
>> basin_grading, but only
>> those portions that are within grading_phases. The query below is my
>> attempt at this, but it returns the acreage of new_vegetation within
>> each entire basin, not just the portion that is also within
>> grading_phases. I thought the ST_Intersects part would take care of
>> that, but apparently not.
>> SELECT
>>    f.use,
>>    n.cat_2008,
>>    Sum(area2d(ST_Intersection(n.the_geom, f.the_geom)))*0.000247105381
>> AS inside_project
>>  FROM
>>    basin_grading f,
>>    grading_phases c,
>>    new_vegetation n
>>  WHERE
>>    ST_Intersects(c.the_geom, f.the_geom)
>>  GROUP BY f.use, n.cat_2008
>>  ORDER BY f.use, n.cat_2008
>> thanks in advance,
>> Marcus
>> postgis-users mailing list postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
