[postgis-users] info
Lee Hachadoorian
lee.hachadoorian at gmail.com
Fri Jun 6 00:11:58 PDT 2008
Hi Chris,
I ran into the same problem on Ubuntu 7.10. Lwpostgis.sql would not run
to completion, and all commands would be rolled back. Believe it or not
I got through it by opening lwpostgis.sql and running each block of
commands separately. I got through everything without ever finding out
what it had been stumbling on, and my PostGIS install is up and running.
Lee Hachadoorian
PhD Student, Geography
Program in Earth & Environmental Sciences
CUNY Graduate Center
Chris H wrote:
> Greets:
> Currently working on installing osm/mapnik support for gpsdrive. This requires
> postgres and postgis integration. As this is a first run with all of this I'm
> rather new to postgis.
> Was wondering if anyone could offer some insight or advise on how to diagnose
> the following problem. The instruction set that I'm following reads as
> follows:
> $> su
> #> su - postgres
> $> <commands...>
> As the postgres user run the following to create the database:
> NOTE: Replace username with the user that will be using mapnik.
> $> createuser username
> $> createdb -E UTF8 -O username gis
> $> createlang plpgsql gis
> This all works fine. No issues here. However the next set of commands barf
> consistently.
> 4.1 As the postgresql super user:
> $> psql -d gis -f /usr/share/postgresql-8.3-postgis/lwpostgis.sql
> $> echo "ALTER TABLE geometry_columns OWNER TO username; ALTER TABLE
> spatial_ref_sys OWNER TO username;" | psql -d gis
> $> exit
> #> exit
> The line "psql -d gis -f /usr/share/postgresql-8.3-postgis/lwpostgis.sql"
> returns the following:
> psql:/usr/share/postgresql-8.3-postgis/lwpostgis.sql:1557: ERROR: current
> transaction is aborted, commands ignored until end of transaction block
> psql:/usr/share/postgresql-8.3-postgis/lwpostgis.sql:1563: ERROR: current
> This error repeats all the way up to 6430 until the command "ROLLBACK" is
> issued.
> How I can diagnose the source of this error as its been plaguing me on 8.2 as
> well as 8.3. System is latest Kubuntu with all updates and the user chris123
> has access to postgresql.
> Kind regards for any insight or info.
> Best and thanks
