[postgis-users] Cutting a Polygon into Pieces with maximum Vertex number
Markus Schaber
schabi at logix-tt.com
Fri Jun 6 04:35:25 PDT 2008
Currently, I have the Problem that I have to cut Polygons with more
than N points in their outer ring into adjacent pieces with a maximum
of N points each. (Inner rings are not present, currently, but may be
later).
The current (simple) approach is that we recursively split the bounding
box into 4 quarters, until each remaining piece has less than N points.
Advantage:
- Easy to implement.
Disadvantages:
- Introduces new points (rounding errors etc.)
- Splits polygons into more pieces than necessary
We have some ideas of some better algorithm, but I wanted to check here
whether someone already has implemented something like this.
Thanks,
Markus
Markus Schaber | Logical Tracking&Tracing International AG
Dipl. Inf. | Software Development GIS
Fight against software patents in Europe! www.ffii.org
www.nosoftwarepatents.org
