[postgis-users] Need help with a query
Bob and Deb
bobdebm at gmail.com
Fri Jun 6 12:09:13 PDT 2008
Hello all,
I'm new to postgis and postgresql and I need some help with a query. I am
trying to visualize some boreholes by connecting
the 3d point geometry from a borehole spatial table to the different rock
formations (non spatial table called lithology). borehole
has a key field called official_name and 3d point geometry called the_geom.
lithology has a key field official_name,layer_number
as well as top_depth, bottom_depth, and lith_type.
x <----- borehole location <---- top_depth of 1st
lith
x <---
bottom_depth of 1st lith <--- top_depth of 2nd lith
x
<--- bottom_depth of 2nd lith
I have figured out how to use ST_MakeLine to make a line that connection for
a borehole down to its total depth ( max(bottom_depth) ),
but I have not figured out a query that would do what I diagrammed above.
I'm using this database to learn both postgis and postgresql and would
greatly appreciate any help.
Thank in advance.
Bob
select official_name, the_geom from borehole
select official_name, top_depth, bottom_depth, layer_number, lith_type from
lithology
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080606/4a2c4451/attachment.html>
