[postgis-users] GIST index speed
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Mon Jun 9 05:39:34 PDT 2008
Mark Cave-Ayland wrote:
> *blinks* this is definitely a bug somewhere - there is no way that
> adding a function wrapper to a constant should make the query several
> orders of magnitude quicker :(
Hmmm. It seems the problem is related to whether or not we copy the
incoming geometry. I've just created a really simple dummy function that
copies the input geometry to a new memory location that looks like this:
Datum LWGEOM_mcatest(PG_FUNCTION_ARGS);
PG_FUNCTION_INFO_V1(LWGEOM_mcatest);
PG_LWGEOM *pgl = (PG_LWGEOM *)
PG_DETOAST_DATUM(PG_GETARG_DATUM(0));
void *mem;
/* Copy somewhere else */
mem = palloc(VARSIZE(pgl));
memcpy(mem, pgl, VARSIZE(pgl)-VARHDRSZ);
PG_RETURN_POINTER(mem);
CREATE OR REPLACE FUNCTION mcatest(geometry)
RETURNS geometry
AS '$libdir/lwpostgis','LWGEOM_mcatest'
LANGUAGE 'C' IMMUTABLE STRICT;
If I then do:
postgis=# explain analyze select count(*) from geography where centroid
&& (select mcatest(the_geom) from geography where id=69495);
QUERY PLAN
Aggregate (cost=7157.29..7157.30 rows=1 width=0) (actual
time=664.406..664.408 rows=1 loops=1)
InitPlan
-> Seq Scan on geography (cost=0.00..7149.00 rows=1 width=4559)
(actual time=181.347..182.944 rows=1 loops=1)
Filter: (id = 69495::numeric)
-> Index Scan using geography_geom_centroid_idx on geography
(cost=0.00..8.28 rows=1 width=0) (actual time=183.543..580.966
rows=32880 loops=1)
Index Cond: (centroid && $0)
Filter: (centroid && $0)
Total runtime: 666.027 ms
(8 rows)
...then I end up with the shorter time query plan??! I think I will punt
this one over to pgsql-hackers to see if they can help work out where
the problem lies.
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
