[postgis-users] GIST index speed
Paul Ramsey
pramsey at cleverelephant.ca
Mon Jun 9 06:19:01 PDT 2008
IMMUTABLE.
I bet when you have the function it's caching the result, and when you
don't, it's re-fetching it. And because the bare result is a toasted
tuple, the re-fetch is a lot more expensive.
P.
On Mon, Jun 9, 2008 at 5:39 AM, Mark Cave-Ayland
<mark.cave-ayland at siriusit.co.uk> wrote:
> Mark Cave-Ayland wrote:
>> *blinks* this is definitely a bug somewhere - there is no way that adding
>> a function wrapper to a constant should make the query several orders of
>> magnitude quicker :(
> Hmmm. It seems the problem is related to whether or not we copy the incoming
> geometry. I've just created a really simple dummy function that copies the
> input geometry to a new memory location that looks like this:
> Datum LWGEOM_mcatest(PG_FUNCTION_ARGS);
> PG_FUNCTION_INFO_V1(LWGEOM_mcatest);
> PG_LWGEOM *pgl = (PG_LWGEOM *)
> PG_DETOAST_DATUM(PG_GETARG_DATUM(0));
> void *mem;
> /* Copy somewhere else */
> mem = palloc(VARSIZE(pgl));
> memcpy(mem, pgl, VARSIZE(pgl)-VARHDRSZ);
> PG_RETURN_POINTER(mem);
> CREATE OR REPLACE FUNCTION mcatest(geometry)
> RETURNS geometry
> AS '$libdir/lwpostgis','LWGEOM_mcatest'
> LANGUAGE 'C' IMMUTABLE STRICT;
> If I then do:
> postgis=# explain analyze select count(*) from geography where centroid &&
> (select mcatest(the_geom) from geography where id=69495);
> QUERY PLAN
> Aggregate (cost=7157.29..7157.30 rows=1 width=0) (actual
> time=664.406..664.408 rows=1 loops=1)
> InitPlan
> -> Seq Scan on geography (cost=0.00..7149.00 rows=1 width=4559)
> (actual time=181.347..182.944 rows=1 loops=1)
> Filter: (id = 69495::numeric)
> -> Index Scan using geography_geom_centroid_idx on geography
> (cost=0.00..8.28 rows=1 width=0) (actual time=183.543..580.966 rows=32880
> loops=1)
> Index Cond: (centroid && $0)
> Filter: (centroid && $0)
> Total runtime: 666.027 ms
> (8 rows)
> ...then I end up with the shorter time query plan??! I think I will punt
> this one over to pgsql-hackers to see if they can help work out where the
> problem lies.
> ATB,
> Mark.
> Mark Cave-Ayland
> Sirius Corporation - The Open Source Experts
> http://www.siriusit.co.uk
> T: +44 870 608 0063
> postgis-users mailing list
