[postgis-users] GIST index speed
Paul Ramsey pramsey at cleverelephant.ca
Mon Jun 9 07:32:32 PDT 2008
Bummer. Well if you need any other cock-eyed theories, let me know :)
P
On Mon, Jun 9, 2008 at 6:34 AM, Mark Cave-Ayland
<mark.cave-ayland at siriusit.co.uk> wrote:
> Paul Ramsey wrote:
>> IMMUTABLE.
>> I bet when you have the function it's caching the result, and when you
>> don't, it's re-fetching it. And because the bare result is a toasted
>> tuple, the re-fetch is a lot more expensive.
>> P.
> Hi Paul,
> If only it were that simple ;)  I'd already tried removing the IMMUTABLE
> definition from SQL definition of mcatest() and it didn't make any
> difference to me - probably because adding a POSTGIS_DEBUG macro shows that
> it only gets called once in total rather than once per iteration of the
> nested loop scan.
> ATB,
> Mark.
> Mark Cave-Ayland
> Sirius Corporation - The Open Source Experts
> http://www.siriusit.co.uk
> T: +44 870 608 0063
> postgis-users mailing list
