[postgis-users] Semantics of difference() function
Andy Anderson
aanderson at amherst.edu
Mon Jun 9 12:10:02 PDT 2008
Difference does seem to provide both sides of the subtractor:
select st_astext(st_difference(GEOMFROMTEXT('LINESTRING(-1 1, 3 1)'),
GEOMFROMTEXT('POLYGON((0 0, 2 0, 2 2, 0 2, 0 0))')))
returns
'MULTILINESTRING((-1 1,0 1),(2 1,3 1))'
-- Andy
On Jun 9, 2008, at 2:44 PM, Martin Davis wrote:
> I see the difference (pun intended) between difference() and split()
> being that split returns the geometries on both sides of the
> splitting geometry, ordered so that the user can decide which one(s)
> he wants. This is more powerful than difference, which only returns
> a single geometry from one side of the split.
> And I agree - I don't think polygons should be reduced to their
> boundary first - the user can do this explicitly if they require it.
> Andy Anderson wrote:
>> On Jun 5, 2008, at 11:43 AM, Martin Davis wrote:
>>> I think the operation also is meaningful for the case (line,
>>> polygon) => line (this is equivalent to a combination of
>>> line.difference(polygon) and line.intersection(polygon) )
>> Ah, yes, split(line, polygon) should definitely be allowed.
>> However, I was originally imagining that split(line, polygon), as
>> well as split(polygon1, polygon2), should be the same as
>> difference(*, polygon), which is geometrically consistent with the
>> simpler forms split(*, line) and split(line, point):
>> ----####---> becomes ---> --->
>> #### 1 2
>> But I see where it might be more useful for the polygon in the
>> second argument to be reduced to its boundary first:
>> #### +--+ ----####---> becomes
>> ----|--|---> becomes ---> ---> --->
>> #### +--+ 1 2 3
>> But the latter is easily produced with the boundary function if
>> someone is so inclined:
>> split(polygon1, polygon2) == split(polygon1, boundary(polygon2))
>> split(line, polygon) == split(line, boundary(polygon))
>> This is more involved, but less confusing to those like me who
>> learn from consistency. What do other people think?
>>> Having thought about this with an eye to implementation, I've take
>>> the definition a bit further:
>>> * The result of split(g1, g2) is a two-component
>>> GeometryCollection, GC(c1, c2).
>> If you define split(line, polygon) as the combination of
>> difference(line, polygon) and intersection(line, polygon), then you
>> could have three components, right? This would also happen with
>> split(line1, line2) and line2 is a linear ring that crosses line1
>> twice.
>>> * The first component c1 is the portion of g1 which lies to
>>> inside, to the left of, or before, g2 (depending on whether g2 is
>>> a polygon, line or point). The second component c2 is the portion
>>> of g1 which lies outside, to the right of, or after g2. * The
>>> types of c1 and c2 are the same as g1. c1 and c2 may be empty, in
>>> degenerate cases (e.g,. where one or more components of g1 are not
>>> intersected, or intersected only at their boundary).
>> It seems to me that "left" and "right" don't always work for lines,
>> as you could also have "below" or "above". Or are you referencing
>> the directionality of g2 here, as you traverse it? But if it's a
>> linear ring, the inner portion will be both to the left and right.
>> I wonder if it wouldn't make more sense to simply use the
>> directionality of g1 instead, describing its pieces as "first",
>> "second", etc., as I suggest in my drawings above?
>> As for polygons, there's no obvious spatial ordering for them,
>> unless you take their vertex order as significant. That seems
>> reasonable to me. For example,
>> split(POLYGON((0 0, 2 0, 2 2, 0 2, 0 0)), LINESTRING(1 -1, 1 3))
>> becomes GEOMETRYCOLLECTION(POLYGON((0 0, 1 0, 1 2, 0 2, 0 0)),
>> POLYGON((1 0, 2 0, 2 2, 1 2, 1 0)))
>> because the first polygon has the first vertex of the original and
>> the second polygon is built from later vertices. I'm not certain if
>> this could be consistently defined, though; it would require
>> comparisons of multiple vertices when one or more are shared by the
>> split polygons.
>>> * Any components of g2 which have a position which is not well-
>>> defined relative to g2 (e.g.which are not intersected, or which
>>> are intersected only partially), are returned as components of c1
>>> (--- this rule is fairly arbitrary - a different strategy might
>>> make equal sense)
>> So c1 is itself a Geometry Collection? This seems unnecessarily
>> complicated; I would prefer a flat object.
>> -- Andy
>>>> On Jun 4, 2008, at 11:49 AM, Martin Davis wrote:
>>>>> To answer a question you posed on your blog, the reason that
>>>>> when you subtract a line from a polygon you get basically the
>>>>> same polygon, rather than say the polygon split into two halves,
>>>>> is that if the latter was provided as a MultiPolygon it would be
>>>>> invalid, because the halves would share line segments down the
>>>>> middle. Also, if the line did not fully overlap the polygon
>>>>> there's no choice - you have to return the original poly. The
>>>>> behaviour is thus consistent between the two cases.
>>>>> Unfortunately the SFS (and no other standard I'm aware of)
>>>>> doesn't define the precise semantics of the overlay operations.
>>>>> So I made 'em up! Hopefully they are consistent and
>>>>> reasonable. There's no doubt alternative definitions which
>>>>> might be useful in some cases - but you have to choose one
>>>>> definition for any given function. (For the situation above,
>>>>> many people would like a "cut polygon by line" operation -
>>>>> hopefully that will get provided as a new function sometime soon).
>>>> I've seen "split" as a term that is commonly used for such
>>>> operations, e.g.
>>>> geometry = ST_Split(geometry1, geometry2)
>>>> This should be defined for geometry1 of dimensionality D ≥ 1 and
>>>> geometry2 of dimensionality D or D-1, i.e. (polygon, polygon),
>>>> (polygon, line), (line, line), and (line, point). The result
>>>> should be GeometryType(geometry) == 'GeometryCollection' where
>>>> for any n GeometryType(ST_GeometryN(geometry, n)) ==
>>>> GeometryType(geometry1).
>>>> -- Andy
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at postgis.refractions.net <mailto:postgis-users at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>> Martin Davis
>>> Senior Technical Architect
>>> Refractions Research, Inc.
>>> (250) 383-3022
> Martin Davis
> (250) 383-3022
