[postgis-users] Creating a Flow Diagram
Andy Anderson aanderson at amherst.edu
Mon Jun 9 15:26:10 PDT 2008
What do you get if you just use
	Select st_asText(graphics.process_dgm.the_geom),
st_asText(spatial_ref.the_geom)
		from graphics.process_dgm, spatial_ref
			where graphics.process_dgm.description = 'Tank' and
spatial_ref.position_ = 2 ;
If you get something, build up from there until it breaks.
-- Andy
On Jun 9, 2008, at 12:23 PM, Bob Pawley wrote:
> Andy
> I've been trying the changes you suggested without success.
> I get an error when I use the + operator (and also if I leave out
> temp_).
> Perhaps I don't understand the use of st_y, st_x max and min.
> I don't want to change the entity merley move it from where it is to
> the center of an established geometry (box).
> Here's the function as it now stands. I still get 0 rows affected
> and the two tables do have geometries (one entity in process_dgm and
> one box in spatial_ref where position = 2) in them.
> Insert into temp_ (the_geom)
> Select st_translate (st_translate(graphics.process_dgm.the_geom,
> st_x (st_centroid(graphics.process_dgm.the_geom)) - st_x
> (st_centroid (spatial_ref.the_geom)),
> st_y (st_centroid(graphics.process_dgm.the_geom)) - st_y
> (st_centroid (spatial_ref.the_geom))),
> ( st_xmax(graphics.process_dgm.the_geom) -
> st_xmin(graphics.process_dgm.the_geom)),
> ( st_ymax(graphics.process_dgm.the_geom) -
> st_ymin(graphics.process_dgm.the_geom)))
> from graphics.process_dgm, spatial_ref, temp_
> and spatial_ref.position_ = 2 ;
> Bob
> ----- Original Message ----- From: "Andy Anderson" <aanderson at amherst.edu
> To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
> Sent: Sunday, June 08, 2008 7:25 PM
> Subject: Re: [postgis-users] Creating a Flow Diagram
>> On Jun 8, 2008, at 5:14 PM, Bob Pawley wrote:
>>> I 'm playing with a variation of the st_translate function we were
>>> discussing last week.
>>> I have created two boxes (spatial_ref) and I wish to place an
>>> entity (graphics.process_dgm) into the temp_ table with the
>>> coordinates  that centers the entity in a specific one of these
>>> boxes.
>>> Here's the code that I have come up with but so far it produces 0
>>> rows.
>>> Select st_translate(st_translate (graphics.process_dgm.the_geom,
>>> st_y (st_centroid(graphics.process_dgm.the_geom)) - st_x
>> The first function here should be "st_x", not "st_y".
>> I don't see anything wrong with this, but you should be able to
>> make a single st_translate call here since max - min won't change
>> in a translation, e.g.
>> (st_y (st_centroid(graphics.process_dgm.the_geom)) - st_x
>> (st_centroid (spatial_ref.the_geom))) +
>> So after matching the centroids you're trying to move the lower
>> left corner of the bounding box to its upper right corner?
>> I don't think you need the ", temp_", but it probably doesn't hurt.
>>> and spatial_ref.position_ = '2';
>> Is spatial_ref.position_ text? If it's an integer, drop the quotes.
>> -- Andy
