[postgis-users] Buffer select from one layer to another?
Obe, Regina robe.dnd at cityofboston.gov
Wed Jun 11 11:39:20 PDT 2008
Abe,
David's is close but doesn't use an index
Try
SELECT  h.* FROM  houses h, roads r
where r.gid=1663 and  ST_DWithin(h.the_geom, r.the_geom, 500)
(although the above really translates to < 500 instead of <= 500)
Hope that helps,
Regina
From: postgis-users-bounces at postgis.refractions.net on behalf of David William Bitner
Sent: Wed 6/11/2008 2:08 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Buffer select from one layer to another?
Abe --
For this type of query, running a buffer is actually not necessary.
select h.* from houses h,roads r where r.name like '%MAIN%' and
distance(h.the_geom,r.the_geom)<=500;
David
On Wed, Jun 11, 2008 at 12:54 PM, Abram Gillespie
<abe.gillespie.lists at gmail.com> wrote:
> Hi All,
> I'm finally starting to do some real production work ... after years
> of simply using PostGIS in example scenarios as I developed zigGIS.
> Pretty funny, actually.  Anywho, could someone enlighten me on how to
> buffer a road and return the surrounding buildings?  This is what I
> have so far:
> touches(h.the_geom, buffer(r.the_geom,500));
> Now I realize the above is a bit complex since " like '%MAIN%' "
> returns multiple road segments, but even working on a single road:
> select h.* from houses h,roads r where r.gid=1663 and
> doesn't seem to return anything.  I'm positive the buffer query should
> return some houses.
> Thanks for any help!
> -Abe
> zigGIS Team
> Obtuse Software, http://www.obtusesoft.com <http://www.obtusesoft.com/>
> postgis-users mailing list
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080611/1b1d719d/attachment.html>
