[postgis-users] Postgis for geology work
Chris Hermansen chris.hermansen at timberline.ca
Thu Jun 12 07:24:34 PDT 2008
Hi Gustavo;
You're certainly starting from the bottom up!  For an application like
this, why not take a look at GRASS?  For at least part of the work?  You
can export your data to PostGIS when the mood strikes you.
Take a look at http://grass.itc.it/grid3d/
Alternatively, if you're determined to write a bunch of code to work in
conjunction with PostGIS, maybe some of that code already exists in GRASS.
Gustavo Ces wrote:
> Hi all,
>     i want to use PostGis for geological work ( fluid
> diffusion,stratigraphy, boreholes, mining...). I was searching in Inet
> but seems there are no tools, data models,... So my alternative is to
> integrate different softwares with python and a database schema. Of
> course, i have to work with 3d geometries ( i´ve read the last thread
> about x3d)... the problem is to operate in a 3d environment.. I´ve got
> to separate visualization and operations ( make something and then
> visualize in browser or other software ). For example, work with
> geometries in a 3d draw environment then export to Postgis with
> Cam2Camp tools and then make some python scripts to calculate what i
> want ( volumes, horizontal and vertical sections, distribution of
> materials, grid creations,integration with numerical models... ). And
> all this into a defined schema to insert boreholes, geophysical,
> geomorphological and geochemical data and integrate all of them... I´m
> scared! And it´s not an easy way...
> But before this, any experience?
> Thanks in advance
> Gus
> postgis-users mailing list
Regards,
Chris Hermansen         mailto:chris.hermansen at timberline.ca
tel+1.604.714.2878 · fax+1.604.733.0631 · mob+1.778.232.0644
Timberline Natural Resource Group · http://www.timberline.ca
401 · 958 West 8th Avenue  · Vancouver BC · Canada · V5Z 1E5
