[postgis-users] Polygonize
Dustin Sampson
dustin.sampson at timberline.ca
Thu Jun 12 11:25:43 PDT 2008
Hey Everyone,
I'm building a "clean" type function that cleans up overlapping
polygons within a table (without using the ST_Union function) but am
running into a few snags.
Basically what I'm doing is
1) Converting polygons -> lines
2) Converting lines -> points
2) Add intersecting nodes where lines cross.
3) Build lines from points & nodes
4) Polygonize new lines.
I can get to stage 3 (so far reliabily) but at stage 4 it doesn't seem
to be building polygons consistently in my testing. I've attached my
original polygon table (testset.sql), my noded lines (noded_lines.sql)
and my function which is in plpython (tnrg_clean.sql).
Does anyone know what is required for the polygonize function, am I
missing some stage to prep the line work before converting to polygons.
Any help would be appreciated.
Thanks for the help,
Dustin Sampson
Type: text/x-sql
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080612/ab6e3955/attachment.bin>
Type: text/x-sql
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080612/ab6e3955/attachment-0001.bin>
Type: text/x-sql
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080612/ab6e3955/attachment-0002.bin>
