[postgis-users] out of memory @ UPDATE a big table
Kis János Tamás kijato at gmail.com
Fri Jun 13 00:22:52 PDT 2008
I have a big table with 21094 rows and each row has a geometry (polygon)
column with average more than 10 point.
When I run the next SQL:
  UPDATE kecskemet_k.foldreszletek AS t SET hrsz=i.szoveg
           FROM ( SELECT t.sorszam, f.szoveg
                  FROM kecskemet_k.foldreszletek t,
                       kecskemet_k.feliratok f
                  WHERE t.geometria && f.geometria
                    AND intersects( t.geometria, f.geometria )
                    AND f.reteg IN ( '11' )
                  ) AS i
           WHERE t.sorszam=i.sorszam;
I get the next message:
ERROR:  out of memory
DETAIL:  Failed on request of size 2941.
********** Error **********
SQL state: 53200
Detail: Failed on request of size 2941.
And now What can I do...? Where is the problem? Where I need to search?
Thanks,
kjt
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080613/e81fc63d/attachment.html>
