[postgis-users] out of memory @ UPDATE a big table
Kevin Neufeld
kneufeld at refractions.net
Fri Jun 13 09:31:52 PDT 2008
:) Hi kjt,
Actually, 21000 is a very small table. There are spatial tables out
there with 1/2 billion rows.
You shouldn't be getting an out of memory error on such a small table.
What happens if you try to restructure your query, like:
UPDATE kecskemet_k.foldreszletek AS t
SET hrsz=f.szoveg
FROM kecskemet_k.feliratok f
WHERE t.geometria && f.geometria
AND intersects( t.geometria, f.geometria )
AND f.reteg IN ( '11' );
If you still get an out of memory error, let us know of your machine's
specs and Postgres settings, like shared_memory, work_mem, etc.
Cheers,
Kevin
Kis János Tamás wrote:
> Hi,
> I have a big table with 21094 rows and each row has a geometry (polygon)
> column with average more than 10 point.
> When I run the next SQL:
> UPDATE kecskemet_k.foldreszletek AS t SET hrsz=i.szoveg
> FROM ( SELECT t.sorszam, f.szoveg
> FROM kecskemet_k.foldreszletek t,
> ) AS i
> WHERE t.sorszam=i.sorszam;
> I get the next message:
> ERROR: out of memory
> DETAIL: Failed on request of size 2941.
> ********** Error **********
> SQL state: 53200
> Detail: Failed on request of size 2941.
> And now What can I do...? Where is the problem? Where I need to search?
> Thanks,
> kjt
> postgis-users mailing list
