[postgis-users] Circle
Michael Smedberg
Michael.Smedberg at redfin.com
Fri Jun 13 16:58:45 PDT 2008
FYI, you can find some documentation on ST_Buffer at
http://postgis.refractions.net/docs/ch06.html
It reads:
ST_Buffer(geometry, double, [integer])
Returns a geometry that represents all points whose distance from
this Geometry is less than or equal to distance. Calculations are in the
Spatial Reference System of this Geometry. The optional third parameter
sets the number of segment used to approximate a quarter circle
(defaults to 8).
Performed by the GEOS module
Do not call with a GeometryCollection as an argument
OGC SPEC s2.1.1.3
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Bob
Pawley
Sent: Friday, June 13, 2008 4:54 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Circle
Is that the only function of the buffer - to create a circle?
Can the buffer modify other functions. If so - what is the criteria?
Bob
----- Original Message -----
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Sent: Friday, June 13, 2008 4:33 PM
> Try it and see :)
> It constructs a circular-shaped polygon around the point.
> P
> On Fri, Jun 13, 2008 at 4:23 PM, Bob Pawley <rjpawley at shaw.ca> wrote:
>> I'm interested in what the buffer actually does.
>> Bob
>> ----- Original Message ----- From: "Paul Ramsey"
>> <pramsey at cleverelephant.ca>
>> Sent: Friday, June 13, 2008 3:46 PM
>>> ST_Buffer(ST_MakePoint(x,y),r)
>>> On Fri, Jun 13, 2008 at 3:35 PM, Bob Pawley <rjpawley at shaw.ca>
wrote:
>>>> What is the best way of creating a circle?
>>>> Mu PostgreSQL Developes Handbook susy it should be - point and
radius.
>>>> Postgis doesn't seem to have this function.
>>>> Bob
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
