[postgis-users] Circle
Bob Pawley
rjpawley at shaw.ca
Fri Jun 13 18:04:53 PDT 2008
Thank you to all.
Bob
----- Original Message -----
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Sent: Friday, June 13, 2008 5:05 PM
Subject: Re: [postgis-users] Circle
> See ST_buffer at http://postgis.refractions.net/docs/ch06.html#id2594743
> Buffer generates a buffer zone around an existing geometry a specified
> distance out (or in if -ve) using a specified number of points. A buffer
> around a point is a circle if you use enough points, if you could buffer a
> point with 4 points, you'd get a square centred on the point instead of a
> circle.
> Cheers
> Brent Wood
> --- On Sat, 6/14/08, Bob Pawley <rjpawley at shaw.ca> wrote:
>> From: Bob Pawley <rjpawley at shaw.ca>
>> Date: Saturday, June 14, 2008, 11:54 AM
>> Is that the only function of the buffer - to create a
>> circle?
>> Can the buffer modify other functions. If so - what is the
>> criteria?
>> Bob
>> From: "Paul Ramsey"
>> <pramsey at cleverelephant.ca>
>> Sent: Friday, June 13, 2008 4:33 PM
>> > Try it and see :)
>> > It constructs a circular-shaped polygon around the
>> point.
>> > P
>> > On Fri, Jun 13, 2008 at 4:23 PM, Bob Pawley
>> >> I'm interested in what the buffer actually
>> does.
>> >> Bob
>> >> ----- Original Message ----- From: "Paul
>> Ramsey"
>> >> Sent: Friday, June 13, 2008 3:46 PM
>> >>> ST_Buffer(ST_MakePoint(x,y),r)
>> >>> On Fri, Jun 13, 2008 at 3:35 PM, Bob Pawley
>> >>>> What is the best way of creating a circle?
>> >>>> Mu PostgreSQL Developes Handbook susy it
>> should be - point and radius.
>> >>>> Postgis doesn't seem to have this
>> function.
>> >>>> Bob
>> >>>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
