[postgis-users] Updated shapefile to update postgres database
Paragon Corporation
lr at pcorp.us
Sun Jun 15 01:08:00 PDT 2008
It shouldn't take that long I don't think. 123,000 records is not a lot.
Granted this is a suboptimal delete.
First thing to verify
1) Make sure to have a btree index on street
2) I assume you have a gist index on your the_geom field already. If not
that could be the culprit.
3) What are your postgresql.conf settings like for work_mem etc. If these
are at there defuats, then that would be a problem too.
The other alternative is to do with an IN instead of an EXISTS. That would
at least not be correlated, but I'm not clear if an
the_geom IN (SELECT ....)
Would match up correctly since I suspect it may use = for compare
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of SenTnel
Sent: Sunday, June 15, 2008 1:34 AM
To: postgis-users at postgis.refractions.net
Subject: RE: [postgis-users] Updated shapefile to update postgres database
Hi Regina!
Sorry took me so long to reply to this post, crazy week around here, but
thank god there's always a weekend to look forward!
This week I tried this method twice but finally had to stop it. First time I
stopped the query after 4 hours thinking there was something wrong. Two
nights later I tried again, left it running all night, next day, almost 10
hours later the query was running still. My table has 123,000+ rows, and
just want to ask you if for such size is normal to take that long, if so
I'll try again, if not, if you don't think it should take that long then you
have any other suggestion?
Thanks again!
Paragon Corporation-2 wrote:
> I wonder if its just called Equals in the old version.
> Try doing just ~=. If your geometries are exactly the same that will
> probably be better anyway
> DELETE FROM mystreets_table
> WHERE street = 'N/A' AND
> EXISTS (SELECT n.street FROM mystreets_table n WHERE n.street <> 'N/A'
> AND n.street > '' AND n.the_geom ~= mystreets_table.the_geom)
> Hope that helps.
> Regina
> SenTnel
> Sent: Saturday, June 07, 2008 4:36 PM
> database
> Hello Regina! Thanks for your help, but when I try running it I got
> this error message:
> ERROR: function st_equals(geometry, geometry) does not exist
> HINT: No function matches the given name and argument types. You may
> need to add explicit type casts.
> :confused:
> Thanks!
>> Here is a thought, but not sure how slow this will be
>> EXISTS (SELECT n.street FROM mystreets_table n WHERE (n.street <> 'N/A'
>> AND
>> n.street > '') AND ST_Equals(n.the_geom, mystreets_table.the_geom))
>> The st_equals might be better to replace with ~= if you want to
>> match exact vertices. I presume ~= is actually more efficient
>> Hope that helps,
>> Regina
>> SenTnel
>> Sent: Saturday, June 07, 2008 2:25 AM
>> Subject: Re: [postgis-users] Updated shapefile to update postgres
>> database
>> Hello! Im confused about this issue:
>> I have a street (polyline) duplicated, one on top of the other, exact
>> same features, same "the_geom", but one bears the street name
>> (column:"street") "main street" and the other bears "N/A" as street
>> name. Now my maps shows the street but the name that shows is "N/A",
>> and I would like to delete the "N/A" polyline, how can i do basically
>> this:
>> delete from mystreets_table street = 'N/A' where 'N/A' = street 'main
>> street'.the_geom (delete from mystreets table the street named 'N/A'
>> where the_geom in 'N/A'
>> equals the_geom in street "main street") another words, delete only
>> the N/A streets that the_geom is same as "main street", I hope you
>> understand,
>> Thanks!
>> SenTnel wrote:
>>> Thanks Regina, Chris and all of you for your help. Im truly newby
>>> but with such help Im ready to start the procedures, Ill keep you
>>> posted of my progress or else if some issue comes along that may
>>> require some light from you, Thanks again and I hope my
>>> problem/solution may be of help to many others,
>>> Thanks again!
>>> SenTnel wrote:
>>>> Hello!
>>>> I would like some help updating a postgres database. This is the
>>>> problem:
>>>> We created the database using shp2pgsql to convert a shapefile that
>>>> contains a city's street details (centerline), after we created the
>>>> database we also created an aditional column to classify the street
>>>> types
>>>> (eg: street, avenues, highways, etc.), now we are working on the
>>>> original shapefile, updating new roads, changes made to highways
>>>> due to constructions modifications, etc., and we want to upload the
>>>> "updated"
>>>> shapefile, without afecting the actual database, another words, we
>>>> would like to convert to postgres the updated shapefile with the
>>>> new information (it cuold be the whole shapefile) but to keep the
>>>> added clasiffication column intact. How can we do that?
>>>> Thanks
>> View this message in context:
>> http://www.nabble.com/Updated-shapefile-to-update-postgres-database-t
>> p
>> 170535
>> 62p17705777.html
>> Sent from the PostGIS - User mailing list archive at Nabble.com.
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> http://www.nabble.com/Updated-shapefile-to-update-postgres-database-tp
> 170535
> 62p17712835.html
http://www.nabble.com/Updated-shapefile-to-update-postgres-database-tp170535
62p17846638.html
