[postgis-users] Getting dimensions of polygon sides
Obe, Regina robe.dnd at cityofboston.gov
Mon Jun 16 08:16:07 PDT 2008
 When I exported it out with Ogr2Ogr, it exported out polygon boxes
angled in the direction the text should be angled (almost like a
placeholder for the text).
So does it look fine in ArcMap, but when you export it out it sometimes
has a line crossing itself? or you can't export it out at all?
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Bruce Rindahl
Sent: Monday, June 16, 2008 11:08 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Getting dimensions of polygon sides
My limited experience is the annotation in ArcMap can be a pretty
bizarre format.  Sometimes is comes out fine - other times it has a line
crossing itself.  If you have a curved annotation, it gets even worse.
Bruce
Obe, Regina wrote:
> Can someone who has ArcMap 9.2 verify for me if it can or can not
export
> annotations in ESRI Shapefile format.  The idea that it can't is
totally
> baffling to me.  So I'm guessing its some misunderstanding. I still
have
> to install my ArcMap 9.2 and become an addict, but I think it would
take
> me a while to get up to speed since all the menu options are too much
> for my little brain to handle.
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
