[postgis-users] Getting dimensions of polygon sides
Bruce Rindahl
rindahl at lrcwe.com
Mon Jun 16 09:09:13 PDT 2008
Obe, Regina wrote:
> When I exported it out with Ogr2Ogr, it exported out polygon boxes
> angled in the direction the text should be angled (almost like a
> placeholder for the text).
That is how I get it. You can use it in ArcMap but the exported
shapefile is exactly as you describe.
Bruce
> So does it look fine in ArcMap, but when you export it out it sometimes
> has a line crossing itself? or you can't export it out at all?
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> Bruce Rindahl
> Sent: Monday, June 16, 2008 11:08 AM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] Getting dimensions of polygon sides
> My limited experience is the annotation in ArcMap can be a pretty
> bizarre format. Sometimes is comes out fine - other times it has a line
> crossing itself. If you have a curved annotation, it gets even worse.
> Bruce
> Obe, Regina wrote:
>> Can someone who has ArcMap 9.2 verify for me if it can or can not
> export
>> annotations in ESRI Shapefile format. The idea that it can't is
> totally
>> baffling to me. So I'm guessing its some misunderstanding. I still
> have
>> to install my ArcMap 9.2 and become an addict, but I think it would
> take
>> me a while to get up to speed since all the menu options are too much
>> for my little brain to handle.
> postgis-users mailing list
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080616/85b5df31/attachment.html>
