[postgis-users] Getting dimensions of polygon sides
Randall, Eric
ERandall at eriecountygov.org
Mon Jun 16 11:22:56 PDT 2008
Maybe not be on the point of this discussion but as the ArcGIS 9.2 "feature to point, line, and polygon" tools output annotation to shape, feature class, etc., sometimes weirdly, and since the attributes have the text, angle, fontsize, etc., I generally export as point shapefiles, then bring them into PostGIS. QGIS and OpenJump labels
reference the font, angle fields so with points set as transparent they look pretty good I think.
-Eric
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net]On Behalf Of Bruce Rindahl
Sent: Monday, June 16, 2008 12:09 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Getting dimensions of polygon sides
Obe, Regina wrote:
When I exported it out with Ogr2Ogr, it exported out polygon boxes
angled in the direction the text should be angled (almost like a
placeholder for the text).
That is how I get it. You can use it in ArcMap but the exported shapefile is exactly as you describe.
Bruce
So does it look fine in ArcMap, but when you export it out it sometimes
has a line crossing itself? or you can't export it out at all?
[ mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Bruce Rindahl
Sent: Monday, June 16, 2008 11:08 AM
My limited experience is the annotation in ArcMap can be a pretty
bizarre format. Sometimes is comes out fine - other times it has a line
crossing itself. If you have a curved annotation, it gets even worse.
Bruce
Obe, Regina wrote:
Can someone who has ArcMap 9.2 verify for me if it can or can not
export
annotations in ESRI Shapefile format. The idea that it can't is
totally
baffling to me. So I'm guessing its some misunderstanding. I still
have
to install my ArcMap 9.2 and become an addict, but I think it would
take
me a while to get up to speed since all the menu options are too much
for my little brain to handle.
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080616/102ed988/attachment.html>
