[postgis-users] Problems Compiling GEOS 3.0
Luigi Castro Cardeles
luigi.cardeles at gmail.com
Wed Jun 18 18:34:49 PDT 2008
hi,
here is the solution. i found that at gentoo maillist.
https://bugs.gentoo.org/attachment.cgi?id=149838&action=view
best regards,
2008/6/18 Frank Warmerdam <warmerdam at pobox.com>:
> Bill Thoen wrote:
>> This probably is the wrong list to whinge about this, but I don't know if
>> there is a geos-users list. Please point me in the right direction if so.
>> Anyway, I'm having lots of problems running make on GEOS 3.0. Errors
>> saying "'DoubleBits.cpp memcpy' was not declared in this scope. and the same
>> for strtod in StringTokenizer.cpp. It looks like there are some #include
>> statements missing or I have a non-standard set of *.h files (I'm using
>> Fedora Core 9, Linux).
>> Anyone else have problems like this and how do I correct it?
> Bill,
> I presume this is an issue with a very new gcc version that is stricter
> about something. I've heard the gcc team is "improving" their include
> files to avoid including stuff that isn't required so perhaps memcpy()'s
> include file needs to be pulled in deliberately now.
> There is a geos mailing list, and trac at:
> http://trac.osgeo.org/geos/
> I would suggest you file a ticket, including information on the gcc
> version, and a capture of the build errors. You also might want to try
> building from "svn trunk" to see if this problem has already been dealt
> with.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam<http://pobox.com/%7Ewarmerdam>
> and watch the world go round - Rush | President OSGeo, http://osgeo.org
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080618/9fe7d0b3/attachment.html>
