[postgis-users] export table from postgis to arcsde
Ragi Y. Burhum
ragi at burhum.com
Wed Jun 18 19:10:53 PDT 2008
A shell script with shp2sde would do the trick.
http://edndoc.esri.com/arcsde/9.1/admin_cmd_refs/shp2sde.htm
or you can always write some ArcObjects code to do it. Hit me up away from
the mailing list and I can point you to the right samples.
- Ragi Burhum
Date: Wed, 18 Jun 2008 02:07:11 -0400
> From: "Paragon Corporation" <lr at pcorp.us>
> Subject: RE: [postgis-users] export table from postgis to arcsde
> To: "'PostGIS Users Discussion'"
> <postgis-users at postgis.refractions.net>
> Message-ID: <000601c8d109$8c3c6be0$4d812e40 at l>
> Content-Type: text/plain; charset="us-ascii"
> I use a PostgreSQL pgagent job to do nightly dumps of a PostgreSQL view put
> as an ESRI shape file. I have people on the other end that have some
> automated routine for importing this shape file into a SQL Server ArcSDE.
> I'm not sure how they do that, but I assume there most be some automated
> tool they use that loads shapefiles into ArcSDE.
> Hope that helps,
> Regina
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> Benedetto Porfidia
> Sent: Tuesday, June 17, 2008 5:49 AM
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] export table from postgis to arcsde
> I have a postgis database and i need to export a view from it to a sde db
> that is a source for arcims service. I should update a sde table with the
> postgis view. How can I do it?
> any hint is appreciated.
> Benedetto
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080618/3b13f1ff/attachment.html>
