[postgis-users] Postgis installation - Trouble with 'make check'
Bill Thoen
bthoen at gisnet.com
Thu Jun 19 09:59:29 PDT 2008
I'm installing PostgreSQL, Proj4, GEOS, PostGIS, GDAL and MapServer on a
Linux FC 9 system and so I'm building it all from source code. I got an
error in the 'make check' step in building PostGIS. Here's the steps I took.
Unpacked the source code into /home/postgres/postgis-1.3.3/ As postgres,
I ran ./configure with the options I wanted.
./configure \
--with-pgsql=/usr/local/pgsql/bin/pg_config \
--with-geos=/usr/local/bin/geos-config \
--with-proj=/usr/local/ \
--with-proj-libdir=/usr/local/lib/
(this worked fine)
Then I ran make, which also appeared to work fine.
Then I ran 'make check' and got the following feedback:
make -C regress test
make[1]: Entering directory `/home/postgres/postgis-1.3.3/regress'
Creating spatial db postgis_reg
ERROR: function postgis_lib_version() does not exist
LINE 1: select postgis_lib_version()
HINT: No function matches the given name and argument types. You might
need to add explicit type casts.
Something went wrong (no postgis installed in postgis_reg).
For details, check /tmp/pgis_reg_12582/regress_log
Looking at the log details, it seems that there's a function missing,
and this caused the make check step to fail. The log file says:
psql:lwpostgis.sql:3856: ERROR: could not find function
"topologypreservesimplify" in file "/usr/local/pgsql/lib/liblwgeom.so"
Does anyone here know what went wrong and how I can fix it?
TIA,
- Bill Thoen
