[postgis-users] Postgis installation - Trouble with 'make check'
Bill Thoen
bthoen at gisnet.com
Thu Jun 19 12:00:48 PDT 2008
I don't think that's it. I can run /sbin/ldconfig with no problems.
Luigi Castro Cardeles wrote:
> hi,
> are you using SELinux? maybe this is blocking access to some
> libraries. try to run ldconfig and see if some brite star show up at
> your uper bar. maybe you have to create some policy.
> best regards,
> 2008/6/19 Bill Thoen <bthoen at gisnet.com <mailto:bthoen at gisnet.com>>:
> I'm installing PostgreSQL, Proj4, GEOS, PostGIS, GDAL and
> MapServer on a Linux FC 9 system and so I'm building it all from
> source code. I got an error in the 'make check' step in building
> PostGIS. Here's the steps I took.
> Unpacked the source code into /home/postgres/postgis-1.3.3/ As
> postgres, I ran ./configure with the options I wanted.
> ./configure \
> --with-pgsql=/usr/local/pgsql/bin/pg_config \
> --with-geos=/usr/local/bin/geos-config \
> --with-proj=/usr/local/ \
> --with-proj-libdir=/usr/local/lib/
> (this worked fine)
> Then I ran make, which also appeared to work fine.
> Then I ran 'make check' and got the following feedback:
> make -C regress test
> make[1]: Entering directory `/home/postgres/postgis-1.3.3/regress'
> Creating spatial db postgis_reg
> ERROR: function postgis_lib_version() does not exist
> LINE 1: select postgis_lib_version()
> HINT: No function matches the given name and argument types. You
> might need to add explicit type casts.
> Something went wrong (no postgis installed in postgis_reg).
> For details, check /tmp/pgis_reg_12582/regress_log
> Looking at the log details, it seems that there's a function
> missing, and this caused the make check step to fail. The log file
> says:
> psql:lwpostgis.sql:3856: ERROR: could not find function
> "topologypreservesimplify" in file "/usr/local/pgsql/lib/liblwgeom.so"
> Does anyone here know what went wrong and how I can fix it?
> TIA,
> - Bill Thoen
> postgis-users mailing list
> <mailto:postgis-users at postgis.refractions.net>
