[postgis-users] need help optimizing spatial join / intersection query
Martin Davis
mbdavis at refractions.net
Fri Jun 20 10:05:28 PDT 2008
Also, the other thing that would help is to split the rain MultiPolygons
into sets of single Polygons.
Martin Davis wrote:
> Thanks for the data, Mark.
> I think your idea of spliitting the rainfall polygons could well
> provide better speed. Processing time is non-linear in the number of
> vertices in a polygon, so smaller polygons should have a much better
> time for running intersection(). Also, as you say, the spatial index
> will be able to reduce the number of intersections that you actually
> have to make.
> Mark Phillips wrote:
>> Paul & Martin,
>> Thanks again for your great suggestions and feedback; I'll try
>> setting up a script to spread the computations out over multiple
>> cores and see what happens.
>> In the meantime, in case you or anyone else wants to experiment with
>> the data I've been using, I've packaged it up and made it available
>> for download here:
>> http://drought.nemac.unca.edu/download/basinrain.tgz
>> That tarball contains two shapefiles --- one for the drainage basins
>> and one for the rainfall polygons, and README file summarizing what
>> I'm trying to do.
>> One idea that just occurred to me, which I haven't had time to
>> actually try yet, would be to first split the rain polygons into
>> smaller pieces, perhaps by intersecting them with some moderate-sized
>> rectangular grid. In general these "rain polygons" are large
>> complicated multipolygons with a lot of holes. It seems conceivable
>> to me that if they were in smaller chunks, the total processing time
>> for my computation might possibly go down, because each actual
>> intersection/area calculation would involve a lower number of
>> vertices. Of course this would be at the expense of a larger number
>> of such calculations, so it's not totally clear that it would help,
>> but it seems like it might, especially since the spatial index will
>> eliminate a bunch of unnecessary calculations. I'll give this a try
>> when I can find the time and see what happens. In the meantime, if
>> anyone has any thoughts about whether this kind of thing would help,
>> let me know!
>> Thanks again,
>> --Mark
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
