[postgis-users] need help optimizing spatial join / intersection query
Mark Phillips mphillip at unca.edu
Wed Jun 18 13:36:19 PDT 2008
Thanks Paul.  I just wanted a sanity check to make sure I was writing my
query in the best way possible.
The vertex counts of the rainfall polygons vary from 50 up to about 15000,
by the way.
--Mark
On Wed, Jun 18, 2008 at 4:20 PM, Paul Ramsey <pramsey at cleverelephant.ca>
wrote:
> Asked and answered? 15 minutes = 900 seconds / 12700 intersections =
> 70ms per intersection calculation. If your 10 rainfalls are fairly
> complex (what's the vertex count?) I don't think that's all that
> terrible.  Removing the intersects() test will make things modestly
> faster, but not earth-shattering.
> P
> On Wed, Jun 18, 2008 at 9:40 PM, Mark Phillips <mphillip at unca.edu> wrote:
> > Hi,
> > I am a relative newcomer to postgis and am trying to figure out how to
> best
> > optimize an interesting query.
> > I have two tables containing (multi)polygons, one representing drainage
> > basins, and the other representing rainfall amounts. The rainfall table
> has
> > an attribute giving the amount of rain in mm associated with each
> polygon.
> >     'basin' table:
> >          gid       integer,
> >          the_geom  geometry
> >     'rainfall' table:
> >         gid         integer,
> >         the_geom    geometry,
> >         rainamount  numeric
> > I want to compute the total volume of rain in each basin by taking the
> > intersection of each basin with each rainfall polygon, multiplying the
> area
> > of that intersection by the rain amount value for the corresponding rain
> > polygon, and adding up all the resulting totals for each basin, storing
> the
> > result in a new table.  I have spatial indexes on both tables, and I've
> > tried the following query using the && operator to make use of the
> indexes:
> >     create table basinrain as
> >         select bgid,
> >                sum(arearain) as totrain
> >           from (
> >                  select b.gid as bgid,
> >                         r.gid as rgid,
> >                         r.rainamount * area(intersection(b.the_geom,
> > r.the_geom)) as arearain
> >                    from basin b,
> >                         rain  r
> >                   where b.the_geom && r.the_geom
> >                     and intersects(b.the_geom, r.the_geom)
> >                  ) foo
> >           group by bgid
> > This seems to work just fine, but it is much slower than I would expect.
>  My
> > basin table has about 2200 rows; their size and geometric complexity is
> > roughly comparable to US county polygons.  The rain table has about 10
> rows,
> > but each one represents a pretty complicated multipolygon with (many)
> > holes.  The query "select count(*) from basin, rain where basin.the_geom
> > rain.the_geom" executes very quickly and returns 12746, which I take to
> mean
> > that (a) my spatial indexes are in fact in place and working, and (b)
> there
> > are 12746 "possible" intersections to be computed in the bigger query
> > above.  On a dual quad-core 3GHz Xeon system with nothing else going on,
> > though, the bigger query takes about 15 minutes to run, which seems to me
> > like a long time for computing 12746 intersections / areas.  (I know that
> > comes out to an average of about 14 intersection/area computations per
> > second, which is way faster than I could do it by hand of course, but for
> > some reason I would expect it to be even faster than that.)
> > Is this surprising to anyone else?  Can someone suggest other ways to
> > optimize this?
> > Thanks in advance,
> > --Mark
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080618/d485d7a9/attachment.html>
