[postgis-users] Postigis self documenting code?
Dane Springmeyer
blake at hailmail.net
Sat Jun 21 09:17:43 PDT 2008
Stanley,
A few weeks ago I placed an issue on the bug tracker that addresses
your 'Issue 2' and I'd love to have feedback since I would be willing
to tackle getting docbook (postgis.xml) meta into db comments however
it makes most sense to do so.
I've written a python script that parses the xml into a sql insert
statement. My thinking is that this calls for a script since we'd want
to be able to update the comments automatically whenever the docbook
changes.
http://code.google.com/p/postgis/issues/detail?id=35
Thanks,
Dane
On Jun 20, 2008, at 10:02 AM, Paul Ramsey wrote:
> Please file in the issue tracker.
> Even better, submit a patch: this isn't something that takes anything
> other than a text editor and the will to be great.
> P.
> On Fri, Jun 20, 2008 at 5:59 PM, Sufficool, Stanley
> <ssufficool at rov.sbcounty.gov> wrote:
>> Issue 1: Can we just name the arguments to the functions rather that
>> using aliases? Is this functionality specific to any version of
>> Postgres? This would give immediate view of args in pgAdmin rather
>> than
>> scrolling through the code to find the aliases and relating them to
>> the
>> types in the function definition.
>> CREATE OR REPLACE FUNCTION addgeometrycolumn (
>> catalog_name character varying,
>> schema_name character varying,
>> table_name character varying,
>> column_name character varying,
>> new_srid integer,
>> new_type character varying,
>> new_dim integer
>> Issue 2: As mentioned before, can we take the Postgis documentation
>> of
>> functions and integrate with metadata as follows?
>> COMMENT ON FUNCTION addgeometrycolumn(character varying, character
>> varying, character varying, character varying, integer, character
>> varying, integer) IS 'Adds a geometry column to an existing table of
>> attributes. The schema_name is
>> the name of the table schema (unused for pre-schema PostgreSQL
>> installations).
>> The srid must be an integer value reference to an entry in the
>> SPATIAL_REF_SYS
>> table. The type must be an uppercase string corresponding to the
>> geometry type,
>> eg, 'POLYGON' or 'MULTILINESTRING'.';
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
