[postgis-users] Normalizing nationalatlas.gov data
Paragon Corporation
lr at pcorp.us
Sun Jun 22 14:06:19 PDT 2008
Yes. Sorry I meant use ST_Union.
INSERT INTO newtable(stusps, the_geom) SELECT stusps,
ST_Multi(ST_Union(the_geom)) as singlegeom FROM somestatefield
GROUP BY stusps
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of David
Jantzen
Sent: Sunday, June 22, 2008 12:32 AM
To: PostGIS Users Discussion
Subject: RE: [postgis-users] Normalizing nationalatlas.gov data
Hi Regina, thanks for the response.
The original data is made up of MultiPolygons, and so the result of
ST_Collect is a GeometryCollection. ST_Multi fails to convert the
collection into a MultiPolygon, maybe it can't do so. So, I guess the
question is whether it's possible to convert a GeometryCollection of
MultiPolygons into a single MultiPolygon.
QuantumGIS can't read GeometryCollections (or at least 0.8.1 can't, maybe
newer versions can?), which is a requirement for what I'm trying to do. I
wonder if it could handle an array of MultiPolygons...
Your second example looks the same as the first, did you mean to type
something else?
Thanks,
David
> ST_Multi(ST_Collect(the_geom)) as singlegeom FROM somestatefield
> GROUP BY stusps
> Or
> GROUP BY stusps
> ST_Collect tends to be faster and if they are single polygons is safe
> to use, with MULTIS it will create GEOMETRYCollections which are hard
> to deal with.
> ST_Union will dissolve some boundaries and can work with MULTIPOLYGONS
> Hope that helps,
> Regina
> David Jantzen
> Sent: Saturday, June 21, 2008 7:37 PM
> To: postgis
> Subject: [postgis-users] Normalizing nationalatlas.gov data
> Hi All,
> I've been exploring the data up on nationalatlas.gov, in particular
> the states, counties and urban areas data:
> http://nationalatlas.gov/atlasftp.html?openChapters=%2Cchpref%
> 2Cchpbound#chppeopl
> I'd like to load these into a postgis-enabled database for use by our
> website. At the same time, I'd strongly prefer a set of normalized
> tables for all this information, so that we don't have redundant (and
> inconsistent) state, county, city information, etc, but rather,
> foreign keys. However, many of the data sets from nationalatlas are
> comprised of multiple polygon records for each entity. For example,
> the Washington state polygon data is spread across 50 rows.
> ?Is it possible to merge the multiple polygons into a single geometry
> object using postgis functions? (I tried various operations
> converting geometries to and from text without success.) Failing
> that, are there comparable data sets out there that can be normalized
> without turning the polygon data into a one-to-many relation?
> Thanks,
> David
> postgis-users mailing list
