[postgis-users] How to trim a GeometryCollection to get a MultiPolygon?
Michael Smedberg Michael.Smedberg at redfin.com
Sun Jun 22 10:14:42 PDT 2008
I have some SQL that intersects a number of multipolygons, and then
attempts to test whether a point is in the result.  In most cases it
works fine.  However, some intersections return a GeometryCollection,
which results in an error like:
ERROR:  Relate Operation called with a LWGEOMCOLLECTION type.  This is
unsupported
Is there a simple and generic way to simplify the collection to trim out
linestrings, etc.?  Through experimentation, I've found that doing an
ST_Buffer(XXX, 0.0) will clean up the GeometryCollection, but I don't
know if that's a safe thing to rely on.
Here's an example of a problematic SQL statement:
SELECT ST_Contains
	ST_Intersection
		GeomFromText('MULTIPOLYGON(((0 0,0 2,2 2,2 0,0 0)),((0
4,2 4,2 6,0 6,0 4)))', 4326),
		GeomFromText('POLYGON((0 1,2 1,2 4,0 4,0 1))', 4326)
	GeomFromText('POINT(1 1.5)', 4326)
And here's an example of a "fixed" SQL statement:
SELECT ST_Contains
	ST_Buffer
		ST_Intersection
0)),((0 4,2 4,2 6,0 6,0 4)))', 4326),
4326)
		0.0
Is it OK to use ST_Buffer to clean up a GeometryCollection?  Or is there
a better/safer way to do this?
Thanks so much!
