[postgis-users] ShapeFile
Bob Pawley rjpawley at shaw.ca
Tue Jun 24 15:58:28 PDT 2008
I have version 1.8.2 of PGAdmin running on XP.
I will try running the select command when I load another shapefile
tomorrow.
Thanks
Bob
----- Original Message -----
From: "Milo van der Linden" <mlinden at zeelandnet.nl>
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Sent: Tuesday, June 24, 2008 3:34 PM
Subject: Re: [postgis-users] ShapeFile
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> PgAdmin crashing being a graphic card error sounds a bit odd to me.
> What version of Windows are you running?
> Have you tried to run a "select * from the_crashing_table" from the psql
> command line interface (psql.exe on windows)
> Paragon Corporation wrote:
>> Which version of PgAdmin are you running?
>> -----Original Message-----
>> From: postgis-users-bounces at postgis.refractions.net
>> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Bob
>> Pawley
>> Sent: Tuesday, June 24, 2008 1:11 PM
>> To: PostGIS Users Discussion
>> Subject: [postgis-users] ShapeFile
>> Hi
>> I just downloaded and installed a shapefile into Postgresql.
>> When I opened the table to view it in PGAdmin my Windows crashed.
>> According to Microsoft it was an Intel graphics driver error. After
>> installing the supposed solution the same error occured opening the same
>> table.
>> Is this a common problem??
>> Bob
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.6 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
> iD8DBQFIYXZ/FHMFRcTlnzoRAsryAKCUFyci/GrgpyVdWQUnWm4xLWn3zgCfUMlD
> wgpjHcht6cRYd+DMpXM3JIg=
> =UFo+
> -----END PGP SIGNATURE-----
