[postgis-users] ST_Contains - WGS84
postgis.domain.thewild at spamgourmet.com postgis.domain.thewild at spamgourmet.com
Fri Jun 27 07:46:27 PDT 2008
+postgis+thewild+172cd4478a.postgis.domain.thewild#spamgourmet.com at spamgourmet.com
a écrit :
> Markus Schaber - schabi at logix-tt.com a écrit :
>> I'm not really sure about that, it may be that the rubberbands get
>> mangled into curves in certain projections. And so vertexes from other
>> polygons might "jump" on the other side of the rubberband.
> Indeed, I would assume that too.
> Projections do not preserve parallelism, so I guess that the same
> geometries projected in two different srids could have different
> ST_Relate results.
> If you want "true results", I think you have to go for a real coordinate
> space like 4326.
Thinking a bit more about it, maybe those spatial relation checks are
always internally performed in unprojected coordinates.
That would be logical, since projections are just a representation of
real things, relations should be checked on the real things rather than
on their representations.
