[postgis-users] Installing PostGIS on Suse
Devrim GÜNDÜZ
devrim at CommandPrompt.com
Fri Jun 27 14:58:08 PDT 2008
On Fri, 2008-06-27 at 13:05 -0400, Ralf wrote:
> My system is a postgres/postgis virgin. The installation of
> postgreSQL, Geos, und proj went well. Now I'm trying to install
> postgis, but the gcc seems to have problems while using the "-lproj"
> option:
> > ~/postgresql-8.3.3/contrib/postgis-1.3.3> gmake
<snip>
> > /usr/lib64/gcc/x86_64-suse-linux/4.1.2/../../../../x86_64-suse-linux/bin/ld: skipping incompatible /usr/lib/libproj.a when searching for -lproj
<snip>
> The following output comes from running configure:
> > PROJ: prefix=/usr libdir=/usr/lib
Maybe you'll need to install proj under /usr/lib64 ?
Devrim GÜNDÜZ , RHCE
PostgreSQL Replication, Consulting, Custom Development, 24x7 support
Managed Services, Shared and Dedicated Hosting
Co-Authors: plPHP, ODBCng - http://www.commandprompt.com/
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080628/5652afdc/attachment.pgp>
