[postgis-users] Installing PostGIS on Suse
Ralf
yukyuk at gmx.com
Fri Jun 27 15:13:30 PDT 2008
Hi Devrim,
thanks for replying!
Devrim GÜNDÜZ wrote:
> Maybe you'll need to install proj under /usr/lib64 ?
Can't I adjust the path so that I don't have to reinstall proj4? And if not, how can I tell configure to install proj4 into /usr/lib64 instead of /usr/lib??
@all:
the lines said "skipping INCOMPATIBLE /usr/lib/xxx.{a,so,...}". Does this perhaps mean I have a wrong version? I have no idea!
> /usr/lib64/gcc/x86_64-suse-linux/4.1.2/../../../../x86_64-suse-linux/bin/ld: skipping incompatible /usr/lib/libproj.a when searching for -lproj
--Ralf
