[postgis-users] Installing PostGIS on Suse
Uwe Seher useher at web.de
Sun Jun 29 22:42:27 PDT 2008
On Sat, 28 Jun 2008 00:13:30 +0200, Ralf <yukyuk at gmx.com> wrote:
> Devrim GÜNDÜZ wrote:
>>  Maybe you'll need to install proj under /usr/lib64 ?
> Can't I adjust the path so that I don't have to reinstall proj4? And if
> not, how can I tell configure to install proj4 into /usr/lib64 instead
> of /usr/lib??
You can create some symlinks in the correct directories.
Bye Uwe
http://www.gispunkt.de
