[postgis-users] Re: Installing PostGIS on Suse [SEC=UNCLASSIFIED]
Roppola, Antti - BRS
Antti.Roppola at brs.gov.au
Mon Jun 30 18:16:50 PDT 2008
We do our own from source install of Postgres/Proj/Geos outside of rpms
(to /usr/local
or /opt) as we found that using the packaged versions sometimes lead to
issues with depenencies.
For example, we are now able to deploy multiple instances of
Postgres/PostGIS (/opt/postgres/8.2
and /opt/postgres/8.3) to facilitate testing/migration.
I used the packaged postgres init.d script as the basis of my own.
The init.d script will use initdb to create the database in which
ever directory DATADIR points to (have a look at
/etc/sysconfig/postgresql)
if it does not already exist.
Cheers,
Antti
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Ralf
Sent: Tuesday, 1 July 2008 11:00 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Re: Installing PostGIS on Suse
Hey, thanks for the heads up.
I tried to play with the settings in the Makefile and made experiments
with symlinks ... nothing worked out. So I uninstalled postgresql and
reinstalled everything from the GEO repository (thanks Brent!). Since I
am on Suse 10.2, everything should work out fine. And it seems as if it
is ... rpm copied the binaries like psql into the /usr/bin directory.
Sorry, but where can I find a start-script for postgresql now, where is
the data-folder? I am not able to locate anything of the installation
except the stuff in the /usr/bin dir.
Thanks a lot!!!
--Ralf
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
------IMPORTANT - This message has been issued by The Department of Agriculture, Fisheries and Forestry (DAFF). The information transmitted is for the use of the intended recipient only and may contain sensitive and/or legally privileged material. It is your responsibility to check any attachments for viruses and defects before opening or sending them on.
Any reproduction, publication, communication, re-transmission, disclosure, dissemination or other use of the information contained in this e-mail by persons or entities other than the intended recipient is prohibited. The taking of any action in reliance upon this information by persons or entities other than the intended recipient is prohibited. If you have received this e-mail in error please notify the sender and delete all copies of this transmission together with any attachments. If you have received this e-mail as part of a valid mailing list and no longer want to receive a message such as this one advise the sender by return e-mail accordingly. Only e-mail correspondence which includes this footer, has been authorised by DAFF
